MAT-705 New version V2!
The MAT-705 is a very small and powerful tuner for portable shortwave equipment, especially designed for the Icom IC-705.
The MAT-705 tunes coaxial fed antennas for shortwave, the usable frequency range is from 1.8 to 54 MHz.
No matter if it is a vertical, a dipole or a directional antenna - the MAT-705 tunes them. Attention is paid to extremely low power consumption.
The MAT-705 is powered by two internal LiIon batteries that can be charged via a USB socket. This way, the radio's power supply is not burdened!
The relays of the tuner are bi-stable, i.e. they do not draw any current after switching.
Once settings have been found, the small tuner remembers them automatically. A maximum of 16000 memory locations are available for this purpose.
This speeds up the tuning process enormously.
The operation is fully automatic if you have set it accordingly in the radio menu, see operating instructions (Tune on PTT).
The MAT-705 tuner is housed in a robust aluminium case, so it can easily travel together with the IC-705.
The required control cable is included, it is 50 cm long and has stereo 3.5 mm jack plugs on both sides.
A WiMo employee (active radio amateur) used a 6m long control cable during his holidays and it worked without any problems.
This way, the tuner can also be operated at the base of an antenna, away from the radio.
Connections: 2x BNC socket, 3.5mm control cable
Indicators: 2x LED (Power, Activity/Tune)
Power supply: Internal LiIon batteries
Changes from version 1 to 2
- LiIon batteries instead of 9V block battery, no need to open the tuner for charging anymore
- No more on/off switch, tuner switches off automatically
- USB-C charging socket, cable included
- LED light guide fixed on the board
Νέα έκδοση V2!
Το MAT-705 είναι ένας πολύ μικρός και ισχυρός δέκτης για φορητό εξοπλισμό βραχέων κυμάτων, ειδικά σχεδιασμένος για το Icom IC-705.
Το MAT-705 συντονίζει ομοαξονικές κεραίες για βραχέα κύματα, το χρησιμοποιήσιμο εύρος συχνοτήτων είναι από 1,8 έως 54 MHz.
Δεν έχει σημασία αν πρόκειται για κατακόρυφο, δίπολο ή κατευθυντική κεραία - το MAT-705 τα συντονίζει.
Δίνεται προσοχή στην εξαιρετικά χαμηλή κατανάλωση ρεύματος.
Το MAT-705 τροφοδοτείται από δύο εσωτερικές μπαταρίες LiIon που μπορούν να φορτιστούν μέσω υποδοχής USB.
Έτσι δεν επιβαρύνεται η παροχή ρεύματος του ραδιοφώνου! Τα ρελέ του δέκτη είναι διπλά σταθερά, δηλαδή δεν τραβούν ρεύμα μετά την εναλλαγή.
Μόλις βρεθούν οι ρυθμίσεις, ο μικρός δέκτης τις θυμάται αυτόματα.
Για το σκοπό αυτό είναι διαθέσιμες το πολύ 16000 θέσεις μνήμης.
Αυτό επιταχύνει πάρα πολύ τη διαδικασία συντονισμού.
Η λειτουργία είναι πλήρως αυτόματη εάν την έχετε ρυθμίσει ανάλογα στο μενού του ραδιοφώνου,
δείτε τις οδηγίες λειτουργίας (Συντονισμός σε PTT). Ο δέκτης MAT-705 στεγάζεται σε μια στιβαρή θήκη από αλουμίνιο,
ώστε να μπορεί εύκολα να ταξιδέψει μαζί με το IC-705.
Περιλαμβάνεται το απαιτούμενο καλώδιο ελέγχου, έχει μήκος 50 cm και έχει στερεοφωνικό βύσμα jack 3,5 mm και στις δύο πλευρές.
Ένας υπάλληλος της WiMo (ενεργός ραδιοερασιτέχνης) χρησιμοποίησε ένα καλώδιο ελέγχου μήκους 6 μέτρων κατά τη διάρκεια
των διακοπών του και λειτούργησε χωρίς κανένα πρόβλημα. Με αυτόν τον τρόπο, ο δέκτης μπορεί επίσης να λειτουργήσει
στη βάση μιας κεραίας, μακριά από το ραδιόφωνο.
Συνδέσεις : 2x υποδοχή BNC, καλώδιο ελέγχου 3,5mm
Ενδείξεις : 2x LED (Power, Activity/Tune)
Τροφοδοτικό : Εσωτερικές μπαταρίες LiIon
Αλλαγές από έκδοση 1 σε 2
- Μπαταρίες LiIon αντί για μπλοκ μπαταρία 9V, δεν χρειάζεται πλέον να ανοίξετε το δέκτη για φόρτιση
- Δεν υπάρχει πλέον διακόπτης on/off, ο δέκτης απενεργοποιείται αυτόματα
- Υποδοχή φόρτισης USB-C, περιλαμβάνεται καλώδιο
- Οδηγός φωτός LED στερεωμένος στην πλακέτα
