CNtoU JCase705 PROTECTIVE CASE FOR IC-70
The Chelegance JCase705 is not just another accessory for the compact transceiver, but a real upgrade that
allows you to take your outdoor radio activities such as SOTA, POTA, fieldday, camping or traveling to a new level.
This robust and waterproof hard case not only effectively protects your high-quality equipment from weather
influences such as rain or dust, but also improves usability on the move.
The IC-705 fits into the case in such a way that the front panel is flush with the metal mounting frame.
All of the radio's connections, for example for the tuner, Morse key, loudspeaker, antenna etc., are also easily
accessible at all times in the frame surrounding the device. A generously dimensioned earthing terminal with
screw connection enables the connection of a counterweight.
If you want to work with an external power supply, the PowerPole connections can be used.
A large storage compartment allows you to store a handheld microphone, jumper cable, spare battery and other useful items t
hat you want to take with you when operating your portable radio station.
The JCase705 is also particularly suitable for emergency radio, as the radio is always ready to hand and ready for use.
The sturdy carrying handle can be folded in and makes transportation to the place of use easier.
Alternatively, the shoulder strap can also be used for carrying over the shoulder.
