We are pleased to announce the NEW Yaesu FTM-500D! 50W, C4FM/FM, 144/430MHz, Dual Band Digital Mobile Transceiver.
‐ Front Speaker, with AESS Dual Speaker System, Delivers Clear and High‐fidelity Audio
(AESS: Acoustic Enhanced Speaker System)
‐ Total 9W (3W: Internal / 6W: Front panel) of Powerful Audio Output
‐ Innovative Smart Operating System "E2O‐IV" with Touch & Go / Search & Go Functions
(E2O: Easy to Operate‐IV)
‐ 144MHz/430MHz: C4FM Digital / FM / AM (Air Band Receive)
‐ True Dual Band Operation, C4FM/C4FM Digital D‐D Dual Receive
‐ Advanced C4FM Digital Mode with AMS (Automatic Mode Select), DG‐ID feature and Smart Navigation
‐ 2.4‐inch High‐Resolution Full‐Colour Touch‐panel Display and Demountable Front Panel Controller
‐ Swing‐Head construction of the Front Panel improves display visibility: 20 degree upwards panel angle is possible
‐ Optional Swing‐head Kit (SJMK‐500) allows the Flexible angle adjustment of the Front Control Panel
‐ Customized Function List (CFL) Display allows checking and immediately executing priority functions.
(Up to 8 functions or settings from the set‐up menu can be registered.)
‐ MAG (Memory Auto Grouping) Function allows Memory channels to be automatically categorized in ALL, AIR band, VHF band, UHF band and OTHER.
‐ VFO Band Skip Function
‐ Memory Channel Data Transfer to the VFO Register
‐ Single‐Touch Spectrum scope function: Instantly switches the operating screen between "Scope display operation" and "Dual Receive operation" while in MAIN channel operation
‐ High speed Band Scope function
*up to 61 channels centered on the current frequency displayed in VFO mode and up to 21 channels of signal information in memory channel mode
‐ 1104 Memory Channels including 5 "Home" channels, 50 sets of memories for programmable memory scan and 999 "Basic" memories.
‐ Built‐in 66ch High precision GPS receiver and External GPS device connectivity,
‐ 1200/9600bps APRS® Data Communication
‐ Wireless Operation Capability with a Bluetooth® Headset
‐ WiRES‐X Portable Digital Node or HRI‐200 Fixed Node capability
‐ Voice Recording of the received and transmitted audio
‐ 50W Stable High‐Power with Heavy Duty Heat Sin
Ο πομποδέκτης FTM-500DE με ισχύ 50W και αναλογική και ψηφιακή διαμόρφωση C4FM/FM καλύπτει τις ζώνες 144/430 MHz. Το FTM-500DE μοιράζεται τα προηγμένα βασικά χαρακτηριστικά της YAESU και χρησιμοποιεί την τελευταία τεχνολογία C4FM Digital.
Διαθέτει μπροστινό μεγάφωνο με σύστημα διπλών ηχείων AESS* (AESS: Ακουστικό βελτιωμένο σύστημα ηχείων).
Ο ήχος του είναι καθαρός και ισχυρός ήχος υψηλής πιστότητας 9W, που παρέχεται από το μπροστινό μεγάφωνο 6W και το εσωτερικό ηχείο της κύριας μονάδας 3W.
To E2O-IV που διαθέτει είναι το καινοτόμο, έξυπνο λειτουργικό σύστημα με λειτουργίες TOUCH&GO / SEARCH&GO / PMG**.
**(PMG: Έλεγχος κύριας ομάδας μνήμης)
Τεχνικά Χαρακτηριστικά
- 144 MHz, 430 MHz C4FM Ψηφιακό / FM / AM (Λήψη airband)
- Πραγματική λειτουργία Dual Band, C4FM/C4FM Digital D-D Dual Receive
- Προηγμένη ψηφιακή λειτουργία C4FM με AMS (Αυτόματη επιλογή λειτουργίας), δυνατότητα DG-ID και Έξυπνη πλοήγηση
- Έγχρωμη αποσπώμενη οθόνη αφής 2,4 ιντσών υψηλής ανάλυσης
- Ο οθόνη είναι ρυθμιζόμενης γωνίας θέασης που βελτιώνει την ορατότητα της
- Λειτουργία απεικόνισης εύρους φάσματος με ένα άγγιγμα
- Λειτουργία Band Scope υψηλής ταχύτητας
- Ενσωματωμένος δέκτης GPS υψηλής ακρίβειας 66 καναλιών και συνδεσιμότητα εξωτερικής συσκευής GPS
- Δυνατότητα ασύρματης λειτουργίας με το ακουστικό Bluetooth®Το προαιρετικό κιτ κεφαλής κεφαλής (SJMK-500) επιτρέπει την ευέλικτη ρύθμιση γωνίας του μπροστινού πίνακα ελέγχου
- Η οθόνη προσαρμοσμένης λίστας λειτουργιών (CFL) επιτρέπει τον έλεγχο και την άμεση εκτέλεση λειτουργιών προτεραιότητας. (Μπορούν να καταχωρηθούν έως και 8 λειτουργίες ή ρυθμίσεις από το μενού ρυθμίσεων.)
- Η λειτουργία MAG (Αυτόματη ομαδοποίηση μνήμης) επιτρέπει στα κανάλια μνήμης να κατηγοριοποιούνται αυτόματα σε ALL, ζώνη AIR, ζώνη VHF, ζώνη UHF και άλλα.
- Λειτουργία παράλειψης ζώνης VFO
- Μεταφορά δεδομένων καναλιού μνήμης στο VFO
- Λειτουργία εύρους φάσματος με ένα άγγιγμα: Εναλλάσσει άμεσα την οθόνη λειτουργίας μεταξύ "Λειτουργία εμφάνισης εύρους" και "Λειτουργία διπλής λήψης" ενώ βρίσκεται σε λειτουργία ΚΥΡΙΟΥ καναλιού
- Λειτουργία Band Scope υψηλής ταχύτητας. Εμφανίζει έως 61 κανάλια με κέντρο την τρέχουσα συχνότητα που εμφανίζεται στη λειτουργία VFO και έως 21 κανάλια πληροφοριών σήματος στη λειτουργία καναλιού μνήμης
- 1104 κανάλια μνήμης, συμπεριλαμβανομένων 5 καναλιών "Home", 50 σετ μνήμες για προγραμματιζόμενη σάρωση μνήμης και 999 "Βασικές" μνήμες.
- Ενσωματωμένος δέκτης GPS υψηλής ακρίβειας 66 καναλιών και συνδεσιμότητα εξωτερικής συσκευής GPS,
- Επικοινωνία δεδομένων APRS® 1200/9600bps
- Δυνατότητα ασύρματης λειτουργίας με ακουστικό Bluetooth®
- Δυνατότητα φορητού ψηφιακού κόμβου WiRES-X ή σταθερού κόμβου HRI-200
- Ηχογράφηση φωνής του λαμβανόμενου και μεταδιδόμενου ήχου
- 50W σταθερή υψηλής ισχύος με ψύκτρα βαρέως τύπου και FACC (Funnel Air-Convection Conductor) *Επιλέξιμο 50W / 25W / 5W
- Υποδοχή κάρτας Micro SD (έως 32 GB)
